p1259 :UPDATED:
p1259 :UPDATED:
Alright guys, here's a little timeline of what I've gone through this weekend.
Problem 1: Car is throwing random misfire codes and idling rough.
Solution: Replaced plugs, coils, fuel injectors
Problem 2: While test driving car after above work was complete car is idling well and pulling nicely until vtec engagement point then just pulling with out any punch and seemingly running out of breath somewhere near 8200rpm and up. Rev limiter kicked in early and threw a CEL, running OBD2 scanner and get code P1259/
Solution: None yet
Problem 3: Car begins not cranking over very strong while starting, also if you let off the gas the car will die. I ordered an alternator to see if this is the reason why.
Solution: None yet. Seems to have gone away, maybe the battery was just at low charge from not driving?
Problem 4: Noticed coolant leak beneath car. Haven't identified the source yet
Solution: Praying it's a loose clamp or something along those lines. It was a loose clamp
Solution: None yet
slates74
03-10-2008 05:38 AM
Rawhide
06-15-2006 02:28 AM
