P1106 Code Help
P1106 Code Help
I have updated the title of this thread to reflect my problem. Here's the story
I get a CEL light for 2 logs: P1106 and P1106. I have checked my ESM wires over and over and they have SOLID connections. Comptech thinks I might have messed up my ecu during the numerous reconnections I did to the ESM box.
Do you think I need a new ecu?
Slow S2k- you posted about a scan tool. Where would I come up with one? Would this be something Honda had and could pinpoint my problem?
Finally, does this code error throw the car into "limp mode" I have noticed that it runs like complete crap after the light comes on.
P1106 is usually seen with a car using some type of piggyback fuel computor, because the piggyback is screwing with the MAP sensor signal. (VAFC, E-Manage) It's also seen with a Comptech ESM or any MAP clamp, with a faulty connection.
On stock cars it is rarely seen. The troubleshooting form the SM pretty much says if it recodes swap a known good PCM, as the BARO sensor is built inside the PCM.
Hmm.. The OBDII reader says Air/Fuel Meter Measurement Parameters or something along that line. The connections on my ESM are perfect. I fished the wiring harness to through the firewall and made all connections outside the car and had others inspect them. The odd thing is my esm box reads 2.93-2.94v which is beyond where it is supposed to cut off right?
Double check the connections on the ESM. are you using t-tap splices, solder or butt connectors. Etc?
2.93V is the spec from Comptech.
http://www.comptechusa.com/instructi...050install.pdf
It's possible your BARO sensor readings may be lower than most due to the altitiude, and the MAP volts is going higher than the BARO. You'd need a OBDII scan tool to verify this.
MAP is used to verify correct BARO operation.
Connections are strong. Soldered and shrink wrapped. The only thing that could be off is I used wire extensions on the black and red but I used the same gauge wire and soldered them perfectly. The altitude I'm at probably isn't the case.
I have an OBDII scanner and it trips the CEL light once I get two P1106 codes. The actual thing it says is "AIR FUEL METERING"
