P0411 CEL code after installing Injen Intake.
I do have a question though. Is there a certain way that the check valve needs to go? I honestly had no idea that piece had any mechanical use other than connecting the two hoses.
http://www.izzeracing.com/Site/Honda...Simulator.html
The simulator allows you to completely remove the air pump system. I am a big fan, used it on my AP1 but in this case I don't think it is necessary at all. It seems like a simple case of operator error, you should be able to get this fixed without resorting to the simulator. There is no reason for an intake to cause this CEL.
It's an idea, but try the more common fixes first! The simulator was $70 and now I don't have to worry about the air pump system what so ever.
Unfortunately the CEL just came back on. Seems to have taken longer this time but it came on when the air pump cut off. I'm not sure what else it could be and the only thing that confuses me about the diagram is that you dont use the metal tubing anymore after installing the intake.
Utah
El S2000
03-08-2014 02:05 PM
