P0411 CEL
Old 12-21-2007, 01:09 PM
A51_AP1's Avatar
Check your IACV (Idle Air Control Valve) which is located on the side of the intake manifold. I has 2 hoses that are connected to it and held on by 2 10mm bolts. Once it is removed, clean it with either throttle body cleaner or brake cleaner (basically the same thing). Clean it throughly and make sure you get as much of the black stuff out as you can. Hopefully that should fix your problem.
Old 12-21-2007, 03:00 PM
Slows2k's Avatar
Don't Phuck with the IAC.. It's not causing this DTC.
Old 12-21-2007, 04:38 PM
jyeung528's Avatar
you're one step behind...
the cel code is unrelated to the iac.
its the secondary air injection system, of which billman posted the diagram.
Old 12-21-2007, 10:06 PM
ShocK's Avatar
Does the secondary system have anything to do with his heater problem?
Old 12-21-2007, 10:21 PM
jyeung528's Avatar
i don't know...billman probably knows.
i would guess yes, since the secondary air injection system's purpose is to heat up the catalytic converter or something to that regard...for better emissions.
however, i dunno how the heater system works...
Old 12-22-2007, 12:14 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Sounds like you have air in the cooling system.
P0411 and the no-heat issue are totally unrelated.
Check the level in the radiator (not the overflow tank) in the morning when it's cold, be sure it's completely full.
Old 12-22-2007, 01:42 PM
Kermdaddy's Avatar
Well guys here goes again. I checked the valve. I blowed both directions but air did not seem to flow????? Is the valve to strong to blow though? Also which way does it go. I tried it both ways but both check engine light came on. Is the little end or the bigger end face the pump? I checked with the engine running and vacuum was on the end closes to the airbox. (hose 8). You guys got anymore ideas?
With the heater issue. There is no fluid in the resevior. I have to get some more Type 2 fluid probably on Wednesday and try to add and purge the system (thanks to Slows2k's info).
Old 12-22-2007, 02:35 PM
ShocK's Avatar
Didn't think so.
Kermdaddy, there should be an arrow on it, just look for it you'll see which way its pointing.
Old 12-30-2007, 12:04 PM
Kermdaddy's Avatar
I took the check valve out and made sure it was installed correctly. There is vauccum on hose #8. I am at a loss. I have checked every hose that I can find and I still cannot locate the one that has the problem. Can you guys help one more time? Slows, any more things I can do?
Old 12-30-2007, 12:09 PM
s2kpunk's Avatar
ive got the same problem and my check valve is on correct also happened after got car back form body shop
s2konroids
10-25-2013 06:41 AM
nicholasbartleet
10-14-2009 08:42 AM
Vadej
08-13-2009 07:43 AM
s2k_dreams
09-21-2006 01:21 AM
kuyabil
04-14-2006 05:55 PM
Quick Reply: P0411 CEL
