P0325 pops up and goes away
2004 S2000 I have gotten a P0325 code pop up and a couple days later if not the next day will go away. Happens randomly and have gone through 2 different knock sensors and also cut and ran another wire to the knock sensor from the ecu. OE sensor was doing it roughly 191k miles and replaced 2 different times with a rock auto and import direct to see if it would change anything. Seems to go away after vehicle is driven short distances a few times cycling ignition. Has anybody ran into this issue before? After driving a month with this issue it seems it is happening more often.
Update: Checked wiring diagram and there is a ground wire that goes off from the knock sensor wire right after the firewall and to the back of the engine head ground. Problem solved.
The following 3 users liked this post by TacoTheft:
bad_driver (03-24-2024)
