Oxygen Sensor Question
Oxygen Sensor Question on AP2 (04-05)
Ok so i got a bank 1 sensor 2 o2 sensor code.
Does an ap2 (specifically the 04-05) have the downstream o2 sensor reading most of the fuel trims? The reason why I ask is because usually the upstream sensor is the really expensive one because it reads the oxygen and fuel mixture and the downstream sensor just reads off of what the upstream sensor is sending.
The reason why I am asking is because the NTK upstream sensor is like 50 bucks and the downstream sensor is 160 and I have never run into that on any other car before. Just wondering if the ap2 (04-05) is different. Ap1 and Ap2v2 are completely different I know.
I just need to buy the right o2 sensor and I just find out hard to believe that the downstream sensor is so much more than the upstream, but i could be wrong!
Btw im buying the NTK - 24250 (downstream) and the upstream sensor is NTK - 24249.
I see the "OEM Sensor" (36531-PCX-014) listed on Honda parts sites (like majestichonda.com) for $240ish. The equivalent Denso sensor is part number 234-4124, and sells for $90-100 from Amazon or other retailers. Is Denso the OEM sensor manufacturer?
I'm actually in the middle of having to do this as well. Proof here: http://photos.smugmug.com/photos/i-6...6b3Ldgj-X2.jpg
I have an 04 and it seems the majestic number for my car is 36532-PZX-A01 and the Denso number is Denso 234-4364. Anyone know why there are such different parts than the one listed above?
Denso 234-4124 (listed above is $95 on amazon)
Denso 234-4364 (found through rockauto is $186 on amazon)
Thanks for the help guys.
Honda has their own system for organizing/categorizing parts, hence the different part number. Same with Denso. The 36532-PZX-A01 is just a repackaged Denso 234-4364.
