Oxygen (O2) Sensor Failure at 63K
#21
I lost the rear O2 in my 2005 @ 61,000 miles due to the converter shifting internally and snapping the tip of the sensor clean off, it seems like more of a common thing that is going on later in life with these cars. Be sure your converter is in good condition and the first "puck" hasn't shifted or you'll just break the other sensor that was just put in and the CEL will come back on.
#22
can a bad primary o2 sensor cause a cel of p0172? I have about 75k on a 2006 s2k.
going through www.oxygensensors.com and inputting 2006. The only sensor I see is walker. Where can I order denso o2 sensor? any difference between walker and denso?
#25
after reading this article, it does make sense that a bad o2 sensor can cause a rich CEL light of 172.
http://www.picoauto.com/applications/lambda-sensor.html
I'll be ordering a new o2 sensor anyways as my tuner suggest I do it if you are over 50k on the sensor.
I found this on amazaon:
http://www.amazon.com/Denso-234-9065.../dp/B001CHFDRU
can someone please confirm that Denso part number 234-9065 is the right sensor to replace. I know on 06+ the primary o2 is a wideband o2 sensor. Would like to know ASAP so I can order it. Thank you.
#26
so anyone confirm? i know the honda part number is 36531-PZX-013
if someone can let me know if honda uses the denso o2...from the amazon and from the denso part number 234-9065, it does state "Air and Fuel Ratio Sensor"
should be getting it tomorrow or wednesday. let me know. Thank you.
