OVERHEAT!
OVERHEAT!
Hi guys,
I got this problem... my car would spontaneously overheat from time to time, regardless of the weather. I noticed that when the car is in overheat-mode, the heater does not blow hot air, as if the coolant is not cycling. After a few minutes of driving though, the temp goes down and the heater starts blasting hot air again... When this first happened, i turned off the engine and noticed that the reservoir under the hood his close to the brim, way past the 'max' mark on the bottle.
I've already replaced the stock thermostat with a mugen unit and changed the coolant and bled the system. Any ideas? Waterpump??
dejavu' U described it to a "T" dos bubbles oonda cooling system.If ya skip down a few posts there is a discussion on this very problem and how to fix.
this one huh?
https://www.s2ki.com/forums/index.php?showtopic=735344
whats weird is that this happened before i touched the cooling system. it was all bone stock when this happened... how did air get in the system all of a sudden? Car is daily driver for 7 years, 80 miles round trip every day. didnt have this issue until last week!
i guess ill try rebleeding with the front jacked up
Originally Posted by r_duff,Oct 7 2009, 04:15 PM
this one huh?
I have the same problem. Car overheat and the heater is not blowing warm air. When I open my hood the reserved tank for coolant is way pass the MAX line. I tried bleeding it and that didnt work. Any suggestion on how to fixed the problem? Where is the thermostat located?
KaNgArOo
11-24-2014 12:23 PM
