Over torqued 10mm bolt
I over tourqued a 10mm bolt and the part that the bolt goes into is stripped. Is there anything I can do to fix this? (The 10mm bolt is NOT stripped)
You could try getting something called a "helicoil" repair (most engineering shops over here in the UK could do this - but you will need clear access to the hole if it is in an awkward position it could mean removing the affected part for repair).
