Over revved engine
Old 10-09-2013, 09:11 PM
  #41
ShocK's Avatar
Originally Posted by beardsley
As a two week old baby owner of a 2002 with 54,000 miles, I mis-shifted twice but hit the clutch immediately. The engine sounds/runs fine. What are the symptoms if damage was done? What are the risks of not inspecting it?
I did this twice trying to pass a spec miata in the same corner, 3-2 shift clutched, 3-2 shift clutched, caught it both times. I pulled the valve cover, check everything, that was about 20k miles ago. Damn spec miatas
Old 10-10-2013, 06:51 AM
  #42
jimboslice's Avatar
You should still inspect your retainers. Even if you pushed your clutch in as soon as you realized what happened, you could have cracked them. There's a thread that was posted up a while ago about a guy that over-revved, and left it alone. He then decided to go turbo and put some AP2 retainers in, and came across several cracked retainers after pulling his VC. He had no symptoms.
Pull the vc and look around with a flashlight. that's all you really have to do.
Old 10-10-2013, 10:46 AM
  #43
Car Analogy's Avatar
Received 1,466 Likes on 1,084 Posts
Or you could listen to Billman and realize that since its an AP2, and he only missed one gear (and he went sideways a bit which means tires slipped instead of motor spinning), he is fine.
Also, this thread is like 1.5 years old, so this happened a while ago.
Old 10-10-2013, 10:51 AM
  #44
jimboslice's Avatar
I was referring the gentleman that bumped this and owns a 2002 with 54k on the clock. Posted yesterday at 4:56pm. I quoted him in my response.
Old 10-10-2013, 10:57 AM
  #45
S2KIrishman's Avatar
October 9th 2013 was a while ago? im sure he was responding to the post above him and not the OP
Old 10-10-2013, 12:17 PM
  #46
I was accussing you of not paying attention and it turns out I was the one that wasn't. Apologies.
Old 10-10-2013, 01:06 PM
  #47
Billman250's Avatar
Received 1,401 Likes on 839 Posts
There will be no symptoms at all.
Broken retainers can go undetected for many thousands of miles, just before the rocker snaps the valve tip off and destroys the engine.
will010100
02-03-2017 10:31 AM
goofball123321
10-13-2011 01:38 PM
dopesilverstone
05-31-2011 10:18 AM
OneSilverS2k
12-06-2010 12:59 PM
s2000amuse
11-07-2006 05:04 PM
Quick Reply: Over revved engine
