Over revved engine
Old 05-22-2012, 07:02 PM
SkateForGirl's Avatar
You could have bent your exhaust valves. You might want to get it checked out
Old 05-22-2012, 07:14 PM
AP1Driver's Avatar
Don't worry about replacing the valve cover gasket. I've had my valve cover off multiple times and have never had a leak, reusing the OEM gasket each time. Just wipe it off on the edge, and make sure to clean any oil from the head casting it rests on. Also make sure to press evenly when putting the cover on over the spark plug tubes until you hear a "plunk" sound of the cover seating. Torque your bolts in order and it'll never leak.
Old 05-22-2012, 07:40 PM
JUSTINTHECOASTIE's Avatar
When removing the head, the spark plug seals tend to rip or tear when reinstalling the valve cover. Since Honda doesn't sell the spark plugs tube seals without the valve cover seal, you might as well replace it as well. The spark plug tubes are sharp and would need oil lube to assist with installation of the valve cover. Replacement of these items instead expensive nor is it time consuming for added piece of mind
Old 05-22-2012, 08:06 PM
hunginator's Avatar
How would I tell if I bent my exhaust valves?
Old 05-22-2012, 08:23 PM
2003AP1's Avatar
I believe in an AP2 you are fine if you over rev the motor. Its not as big a deal as on an AP1.
Old 05-22-2012, 08:33 PM
hunginator's Avatar
Hmm okay. I just would rather be safe than sorry right?
Thanks for all your help guys so far!!! I really appreciate it.
Old 05-22-2012, 08:46 PM
blasphemy101's Avatar
Compression/Leak down test can often tell you when they are bent. Keep in mind the results are sometimes misleading...
Old 05-22-2012, 09:33 PM
ringo14's Avatar
you need a leak down more than compression
Old 05-23-2012, 12:09 AM
05thumper's Avatar
Wrong, they do.
Old 05-23-2012, 04:27 AM
Originally Posted by 05thumper
Wrong, they do.
You're right, idk why I was think about the rubber gaskets that the head bolts go inside, probably because it was a recent job I did LOL
Quick Reply: Over revved engine
