Over revved engine
Hey every one,
I went out for a nice a cruise the other day and went from redline 3rd gear to 2nd instead of 4th by accident.
Luckily, I think I reacted fast enough and it only stayed in 2nd for less than a second. The car also started going sideways till I clutched in.
I don't hear any funny sounds and car seems to drive normally.
My question: what are the chances that I damaged something and is there anything I can look at?
Removing the valve cover and inspect the keepers and retainers. Look for a sunk valve stem as the keepers and retainers can crack, this will be the net effect if severe. ap2 are beefier though yes.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
If you don't mind me asking, how were you holding the shift knob when you did this?
http://www.youtube.com/watch?v=Ald7V...e_gdata_player
That's how I shift and I have not missed a gear since.
Lol, old TI song in the back, hope that wasn't a cd
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Inspect retainers, remember to replace valve cover seal, and spark plug tube seals as well. Also, it could take days before you notice symptoms of a bent valve
It shouldn't be. There's nothing labor-intensive about inspecting the retainers - you literally take the valve cover off and visually check them for shifting upwards on the valve stem, but I wouldn't trust anyone but a competent mechanic very familiar with the S2000 and the cracking retainers problem. Some members don't feel a visual inspection of the retainers while they're in the car is enough to assess cracked valve retainers, removing them wouldn't be a super-complicated procedure for a mechanic familiar with the S2000. A very reputable, local shop quoted me ~$300 for replacing my valve retainers with the AP2 version.
Also, I believe Billman250 has said that in an AP2 (with the F22) you would have to miss 2 gears before incurring damage. The F20c, on the other hand, runs to the ragged edge of the AP1 retainers' threshold. ANY amount of over-rev (OVER 9000!!!!!) can crack retainers.
In any case, I would have it checked out, though.
http://www.youtube.c...be_gdata_player
Dry shifting is going to kill those poor syncros.
not if he had the clutch depressed
