over revved..
well, it has been a while since i miss shifted. about 2 years ago. i mean the car runs fine. i do get the car checked every time it needed one and the car has 34,xxx miles. i miss shifted at about 7,xxx miles. is there anything to be worried about?
I don't think you have anything to worry about if you misshifted 27,000 miles ago. There's obviously no problem.
But if you meant you misshifted again doing 7,000RPM, you are probably okay. I have not heard of any similar problem with an AP2, plus you were not at redline when you misshifted.
Originally Posted by ans2k,Nov 6 2008, 09:46 PM
sry what i mean was, i miss shifted from 4th to 2nd about 27,000 miles ago and i was reading some thread that got me worried.
i mis-shifted and had good compression numbers. i replaced the retainers for peace of mind.
a couple years later...i had bad compression, warped valve guides, warped valve face...
i would change the retainers for peace of mind and continually check the compression.
don't think you're fine forever.
