Other causes for oil burning
Old 03-03-2001, 01:04 PM
ultimate lurker's Avatar
LC,
Oil consumption for new engines is not unusual (although my S2K didn't burn a drop to my surprise). However, my car had 10K miles on it when I suddenly consumed a lot of oil - hence my personal investigation into breather tube issues.
It seems quite common for many people to burn a lot of oil to start and gradually taper off over time and that wouldn't worry me if I were a new owner.
BTW, would that exotic be a Porsche (12 quarts) or a large displacement Ferrari?
UL
Old 03-03-2001, 03:56 PM
dlq04's Avatar
Received 5,797 Likes on 3,416 Posts
Well, if spirited driving is the number 1 culprit after break-in, then I'm going to use a lot of oil when spring gets to Michigan. But with two MGs in the garage I already invested in an oil well, and know the routine well.
Old 03-04-2001, 06:05 AM
L. Cunningham's Avatar
The other car is a Jaguar - XK 140, also a roadster. And, also a heck of a lot of fun. Both cars (the Jag and the S2K) makes stops for gas a lengthy process because of all the attention and questions. The shy need not apply for membership in either of these clubs.
Old 01-13-2003, 05:24 PM
Administrator
krazik's Avatar
Bring to top.
UL did you ever come up w/ a solution you are happy w/ ?
I am burning more oil the harder and harder I drive the car
Old 01-13-2003, 09:52 PM
Nope, I just resigned myself to topping up the oil after track days.
That said, now that I've got an AEM on and have removed the hard lines, a catch tank would be a piece of cake.
UL
Old 01-13-2003, 10:41 PM
Administrator
krazik's Avatar
true. How bad is the burning oil on the engine, o2 sensor, cat etc?
Old 01-14-2003, 02:53 AM
dlq04's Avatar
[QUOTE]Originally posted by dlq04
[B]Well, if spirited driving is the number 1 culprit after break-in, then I'm going to use a lot of oil when spring gets to Michigan.
Old 01-14-2003, 03:24 AM
Former Sponsor
ReedZ's Avatar
Maybe this will help...
Regards
Old 01-14-2003, 03:48 AM
Yellow Streak's Avatar
UL
My temporary fix for this is a K&N breather mounted on the fender:
I am going to replace that with a catch can. My biggest fear was that the Comptech kit was sucking on that breather pre-blower which I would think can't be good for the blower. If you went through a quart of oil - that's a lot of oil to suck through all of the intake parts, no?
-YS
Old 01-14-2003, 05:37 AM
dlq04's Avatar
Regards
Quick Reply: Other causes for oil burning
