Opinions on this nitrous setup?
Ok, heres what I plan to purchase as of now-
Zex Wet Kit
Denso Iridium IK24's (Are these really 50 bucks?!?)
NOS Fuel Pressure Safety Switch
MSD Window Switch
Few questions, what else do I need to make the window switch work? And where can I find ~8800 pills? Or is it even needed with the Safety Switch? Does the ECU kill fuel from the pump or injectors?
Is there anything else needed to make this a safer system?
Zex Wet Kit
MSD Window Switch
the pills are sold in packets, and you could purchase them through summitt racing. The denso are excellent plugs and perform well even without nitrous. Are you going to retard the timing?
I thought that was impossible without a standalone? I didnt plan to purchase one because I wasnt sure it would be needed for a 50 shot. Will it? Should I maybe go for IK27s in that case?
thats a really tough call on this car. I have always received mixed responses for NX and Holley. NX techs stated for 50 shots on the S you do not need to retard the time, while Holleys techs state 2 to 3 degrees. I beleive if you are not going to use a higher octane gas then you should retard the timing.
55shot & below, no retarding needed. I have run a 75shot with no timing adjustment & no probs, but that may have been pushing it! You should be just fine for a 35 shot.
