Opinions on this nitrous setup?
I am considering spraying on my s2000. I dont want anything huge at all, less than a 50 shot. I also dont want to heavily modify my car, and fill the trunk with a huge bottle. So I was considering running a small 35 dry shot sneaky pete system. I had a few questions-
Would a tuned dry 35 shot be safe? How long would I get out of one of those bottles?
Any other opinions would be great. Thanks.
where and why are you hiding. I have two bottle in the trunk: one is 15lbs and the other is 10lbs. If you are hiding then you would probably need a remote opener which does not work on the smaller bottles. They will only work with the standard nitrous bottle connections.
I guess I just thought it would be cool to have a hidden kit. However one of my original ideas was to place it in the well, and have a false floor made, so it would be easy to access, yet hidden. Any opinions on the NX Incognito system?
Did alittle more research and found that the hidden systems to not utilize any fuel enrichment what so ever. The Zex dry system bumps fuel pressure via the FPR to increase fuel delivery. However if I am going to spend that much the wet kit isnt far off. Then again Im at the opposite end of the spectrum and have lost sight of what I originally intened to do.
But I suppose if your going to spray you better not half ass it. So either a Zex wet or dry kit, and maybe a smaller bottle.
