Open vs. closed deck
Wondering what the advantages and disadvantages to running a closed deck (versus our open deck design) are. Should I consider closing the deck off (obviously allowing for coolant flow) when I go to sleeve the block?
it's all depends on the design.
for most of the honda block, unless you are running extremely high boost, a close deck is not needed.
as you already notice, a open deck design allow the coolant flow thru which is better(for most of the boost situation).
How much boost will you be running to need a closed deck? The only S2000 motors I know of with a closed deck are running GT42R's on insane amounts of boost and 800+ horsepower.
I don't know yet, but I didn't know enough about the advan/disadvan of having a closed deck to make an informed decision on whether I should close it. I suspected it was to prevent excessive cylinder walk, particularly under high boost (large forces), and this somewhat confirms my suspicion.
I believe I would be quite happy with 400 whp, so this doesn't look like a necessity for me. It's a very inexpensive upgrade to make if the block is already in the open (<$100), therefore if it offered an extra degree of reliability for a few Andrew Jacksons I would go ahead and do it.
Thanks, guys!
Thanks, guys!
Think 800 horsepower or more needed to justify a closed deck block.
Tim
Tim
id say ( and ive spoken to several of my buddies) the open deck F motor can handle up to 400 hp safely. anything more - def. get it sleeved/close it up.
i know there were threads about just using a block guard - that may be a safe/cost effective way as well. ( not bulletproof - but safe )
