Only one wheel spinning in snow...lsd bad?
So got stuck in my buddies driveway, trying to backout i just spun tires, well tire.....only the passenger rear wheel would spin according to them. Then later when we got it moving but yet still spinning i opened my drivers door and saw the drivers side wheel spinning. Weather they both were or not I am unsure. But as I have been told these cars all come with LSD from factory, and I have been under the impression it should prevent this. Insight?
the diff in the s2000 is torsen diff, it needs some traction for the lsd to work. so when one wheel is lifted off the ground, or has basically no traction (like in snow) the lsd will act like an open diff.
next time that happens you can try to slightly apply the brake which should help transfer some power to the other wheel
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Ahhh gotcha, theyre all seasons but theyre bald, and my shop is having a huge problem with getting my snow tires in but theyll be here today after 4 weeks of nonsense. Thanks for the info.
