Only front braided lines OK?
Originally posted by S2kRob
Can you use a Dremel to cut the nut off?
Originally posted by Triple-H
dlq04 - thanks for the news about it being a three part system, not a 2-part.
Cheers,
Ben
Former Sponsor
what about cutting the nut off, unflaring the rigid brake line and install a new nut and reflare it so it stays on like normal?
where can i buy one of those nuts and is there a flare tool or something else i could use?
thanx for all the help!!!
[QUOTE]Originally posted by VTECxTurbo
[B]what about cutting the nut off, unflaring the rigid brake line and install a new nut and reflare it so it stays on like normal?
Former Sponsor
i believe it's a US type flare where it's female-like, correct me if i'm wrong.
i guess if i cut off a flare, it'd only be no more than a quarter of an inch. that shouldn't effect anything too much.
now where would i get a new nut??
[QUOTE]Originally posted by jschmidt
[B]Talking about two different things here. This is a description of the ABS system (which is also dependent on power brakes to work).
Aarron,
I cant beleive you turn to board member for help....J/K!
That nut looks impossible...maybe just cut it off and get a replacement is the best way to go...
DaRKCrow
"You need new tires....its kinda scary when the rear are bald!"
DaRKCrow
