Only front braided lines OK?
Old 10-28-2001, 08:59 PM
Former Sponsor
RevJunky's Avatar
Default Only front braided lines OK?
does anyone know if it's ok to have only stainless steel braided lines on the front and not the rear?
i stripped a bolt while installing the rears and it seems almost impossible no matter what i do to get it off.
Old 10-28-2001, 09:10 PM
Banned
gregstevens's Avatar
It won't hurt anything...
But get a line wrench for that nut that you stripped...if, and I'm sure that it is, the one that I think you stripped. Line wrenches are closed 3/4 of the way around the nut and provide the maximum contact with the nut...they are also called flare nut wrenches.
Old 10-28-2001, 09:17 PM
Former Sponsor
RevJunky's Avatar
thanks! i'll check that out. but the nut is REALLY stripped, i mean pretty much round half way around. would you happen to know where i could get a line wrench?
Old 10-29-2001, 03:47 AM
CoralDoc's Avatar
If the nut is REALLY stripped, it might be time to break out the dreaded VICE GRIPS . A little Liquid Wrench might help too.
Old 10-29-2001, 03:57 AM
cdelena's Avatar
It is likely one of those (too) soft fittings in the brake line that I know can be stripped even with the proper flare wrench. If you attack it with a plumbers tool be careful not to destroy it. It will require either replacement of the brake line or cutting and flaring a new fitting and neither will be easy.
Old 10-29-2001, 04:14 AM
Triple-H's Avatar
Just braided lines on the front is OK, but get the stripped nut fixed!!!
The last thing you would want is to have that thing come off under the incredible pressure of hydraulics and leave you with no brakes on that wheel/part of the system.
Is the S2000 brake system a 2-part?
Part one- Front Left and Back Right, Part two- Front Right Back Left???
Old 10-29-2001, 04:47 AM
jschmidt's Avatar
[QUOTE]Originally posted by Triple-H
[B]Is the S2000 brake system a 2-part?
Old 10-29-2001, 05:35 AM
dlq04's Avatar
Received 5,800 Likes on 3,419 Posts
Jim, did Honda change it?
Here's what I have researched:
Power assisted 11.8" vented front discs; 11.1" solid rear discs,
4-wheel disk brakes incorporate a anti-lock brake (ABS) system. It consists of 4-speed sensors, one in each wheel. It uses a 3-channel system; each front has it
Old 10-29-2001, 05:39 AM
cdelena's Avatar
I think the whole reason it is stripped it the soft flare nut has bedded into the hard fitting. It is not going to leak. It is not an emergency.
Old 10-29-2001, 05:46 AM
S2kRob's Avatar
Can you use a Dremel to cut the nut off?
Quick Reply: Only front braided lines OK?
