one lug nut broke off....
The wheel studs ARE pressed in. They have to be installed with a wheel stud puller, or flat lug and washers.
I still don't know if I have the clearance to fit it from the back. Many cars do, some don't.
I hope that I don't regret second guessing Billman. But, I have heard reports from my friends that have broken lug nuts that the hub needs to be removed (and sealed bearing replaced) for the procedure unless you cut away part of the dust shield.
Here's an old link: https://www.s2ki.com/forums/index.ph...pic=297722&hl=
Originally Posted by RunUrAss' date='Mar 25 2007, 07:20 PM
and also is it drivable for the time being? the S is kind of my daily driver
Originally Posted by milkbubble @ Mar 26 2007' date=' 09:41 AM
I have driven for months on a car with a broken stud. Im not saying its OK but I have got away with it before.
P.S. I really did do that.
I did the same thing on my old Pathfinder. You can get away with it for a little while, but you can't pass inspection with it (at least I couldn't). You do have to take the hub off, which was a big pain in the ass on the Pathfinder (being a 4wd Nissan), but might not be that difficult on the S. After its off, you can actually tap the old stud out and the new one in with a good mallet. Its easier than you would think.
And an FYI for the future, ~85 ft/lbs is a good place to torque your lug nuts to. Or we'll use the 2 grunt method with a normal tire iron
Yeah.. I don't know about the rear wheel, but I broke a stud off of the front hub and there just isn't enough clearance to pound the stud out. I had to take the hub assembly out and use a hydraulic press to separate the pieces in order to replace the stud... I'd let a professional do it. But good luck!
whats the torque spec for tightening lug nuts? anyone know?
i actually was tightening the lug nuts earlier and felt that i could tighten it more but didnt want to strip anything, i have a history of over tightening stuff and stripping bolts/nuts doh!
i have a torque wrench...should use it more often
