Old transmission fluid
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Ill be changing out the transmission fluid tomorrow if I can find someone that will lend me their jack stands. I will be using Honda MTF. What is the weight of this fluid? The containers that I see on the internet is gray with a green label and red band across the top that says, "Honda Genuine HG". Here is the link below:
https://www.google.com/search?q=hond...F%3B852%3B1136
Is this the only fluid that Honda provides?
What should my old fluid look like?
Change the fluid with confidence....slipping issue is automatic trans related.
Do a search for trans fluid...legions of threads on it (only a sampling here). Can't go wrong with Honda Fluids.
Utah
Utah
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I did a search and also went shopping but I can't find amsoil and or any other brand that i felt comfortable using. So I'm going to Honda first thing tomorrow morning to get some fluids. I may do the diff also since the car will be up anyways and will be using Mobil1 synth gear oil. Should I do a flush if the diff fluid has not been changed out?
When I first got my car (used) I just drained the old fluid out and put the new fluid in.
It sounds far too long to me, I think it's time to change it. Most people find the tranny getting notchy after 8-10k miles on the fluid. I dump mine once a year regardless of mileage which is overkill but it's cheap maintenance.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Originally Posted by HighwayStar' timestamp='1389073936' post='22953203
sorry to Hijack here but i changed my Trans oil at 55k. And now im at 100k should i do it agian or im i changing it too early?
Go with the severe service interval on the diff, 15K miles. Change it now while you're doing the tranny fluid.
Changing the tranny fluid and the diff fluid is some of the least expensive maintenance you can do on these cars, even less cost than an oil change. I find it easy to do the tranny fluid and diff fluid at the same time, so go with equal intervals for both units, say 10k-15k miles.
