Old transmission fluid
I read on other forums that changing old transmission fluid can cause the transmission to start slipping. Is this an issue with the manual transmissions found on the s2000? The car has 94000 miles and I'm unsure if the transmission fluid has ever been changed.
That shouldn't be a problem with the s2k transmission. That slipping deal you are talking about May happen with automatic transmissions,but not manual ones.
Why would it affect automatic transmissions but not manual transmissions? If the transmission fluid is so old, why has it not broken down yet and caused grinding or damage?
Manual trannies have no hydraulic orifices to worry about, and varnish is less harmful and less likely. Old manual tranny fluid mostly suffers from shearing down and becoming very thin, not nearly as much heat related issues as auto trannies. You might notice notchiness as manual tranny fluid shears with age, grinding would only be in extreme neglect cases but it might be possible. I think there is less chance of damage though compared to an auto tranny. Often the issue with manual trannies can be corrected when the fluid is changed, auto trannies may need to be rebuilt or entirely replaced when neglected.
Amsoil Manual Synchromesh Transmission Fluid 5W-30 is what I just used yesterday (just like in that pic above). Dont forget about the fluid in your rear differential either.
Different transmission and different usage place varying demand on lubricants so change schedule will very greatly. Generally the S2000 transmission lube needs relatively frequent replacement for good performance.
what kind of driving are you doing? if it's running around town and occasional track days I would use the honda oem mtf fluids.
On my cars that see mostly track driving I use Motul Gear 300 and Motul Gear 300 LS (for the diff)
Ill be changing out the transmission fluid tomorrow if I can find someone that will lend me their jack stands. I will be using Honda MTF. What is the weight of this fluid? The containers that I see on the internet is gray with a green label and red band across the top that says, "Honda Genuine HG". Here is the link below:
https://www.google.com/search?q=hond...F%3B852%3B1136
Is this the only fluid that Honda provides?
What should my old fluid look like?
