Is it okay to install CAI on 2007 S2k?
Old 06-09-2007, 03:24 PM
toroy82's Avatar
Cool Is it okay to install CAI on 2007 S2k?
Is it okay?
2007 s2k doesn't have hole on side of bumper.
But CAI goes to right side of your bumper.
Does anyone installed CAI on 07 s2k?
Another Q,
If it is okay, Should I go with Injen? or AEM V2?
Which one has better sound?
Thanks.
Old 06-09-2007, 04:16 PM
Money2536's Avatar
I don't know how much research you've done, but a CAI won't do much for you. If I were you, I would look into K&N FPK for you '07 instead. That's if you are looking for sound. I would look into buying a snorkle.
Old 06-09-2007, 05:02 PM
R3DS2K's Avatar
7. ECM logic/SSD mode. The ECM/PCM performs several functions after the key is turned off and removed. You must wait at least 15minutes after the key is turned off before unplugging the PCM. If you unplug the PCM while it's performing the SSD (self shut down) tests you can permanently damage the PCM
if u do.. dont unplug the battery so soon.. if u gonna reset the ecu
https://www.s2ki.com/forums/index.php?showtopic=340163
Old 06-09-2007, 05:37 PM
toroy82's Avatar
What is K&N FPK? FPK?? Sorry. --;
is it FIPK Air Intake (Fuel Injection Performance Kit)?
Short Intake?
Old 06-11-2007, 12:36 PM
R3DS2K's Avatar
i tink its just a drop in filter.. but im pretty sure u want the intake for the sound more than anything else??
Old 06-11-2007, 01:47 PM
nichigo's Avatar
Yes you can install a CAI. I recently installed the AEM v2 CAI in my MY07. here's a link to the write up i made:
https://www.s2ki.com/forums/index.ph...&f=22&t=493473
Also has a link to a comparison vid I made of the sound. I <3 the sound...
Let me know if you have any questions
Old 06-11-2007, 05:47 PM
AllenS2K's Avatar
I installed the F5 CAI (www.f5air.com) in my 07 for about a week. I had to take it out because my Strut Bar would not go back on with the intake, so I had to give up one, so I decided to go with another intake setup.
I can't tell you too much about the sound because I could not hear the difference over my exhaust....
Old 06-11-2007, 09:53 PM
toroy82's Avatar
Yeah. Actually I don't care about performance. My car is fast enough.
I don't want to cut my front bumber. I just want sound! Thanks for info!
Old 06-12-2007, 04:54 AM
nichigo's Avatar
AEM V2 Cai has best sound imo. U don't have to cut your front bumper...but you have to cut some of the inside of the fender wall.
Old 06-12-2007, 02:03 PM
the_catalyst's Avatar
I have the fujita (allensk2's actually) and the sound is great especially at WOT. I've also heard the AEM (regular and V2) and it sounds excellent. It's up to you which one you want to go with.
The K&N FIPK is acutually an intake (not just a drop in filter) which is a popular purchase for many. The difference is that the filter remains in the engine bay, in a similar location to the OEM box. The CAI's mentioned go down to pass side of the car, behind the front bumper.
Lastly, you have to cut a small portion of the undercarrige (plastic piece) to allow the pipe to pass through. It's an easy procedure, just have to be willing to cut your car! there's an excellent write with pics in the Under the Hood/DIYs and FAQs section, one for the Fujita and at least one for the AEM.
HTH
Quick Reply: Is it okay to install CAI on 2007 S2k?
