Oil on spark plugs and coil packs
Old 12-06-2010, 07:09 PM
mrpoopiehead's Avatar
Originally Posted by JFUSION,Dec 5 2010, 08:43 PM
you had a big oil leak there. If the oil under the coil cover got heavy enough it would seep into the plug wells, the coils will seal out dust and dirt but they aren't watertight. I couldnt imagine an engine running very long without spark plug tube gaskets, they must be under the valvecover, otherwise that would be a major fubar. The number 4 plug seems to have some deposits on it, likely related to the oil leak.
I'll check again, but I'm almost certain that there were no tube gaskets in there and I've been driving my car for two years like this. I will definitely fix this ASAP though.
I'm pretty sure the oil didn't get past the threads of the spark plugs since I didn't notice white smoke coming out of the exhaust before, but when I pulled out the spark plugs, some oil got into the cylinders and I saw a bit of white smoke when I started the car.
I'm hoping the 4th spark plug is just because I have a bunch of oil in the spark plug tubes.
Old 12-06-2010, 07:10 PM
Originally Posted by Nick.,Dec 6 2010, 04:25 AM
where are you located? i have a gasket set sitting on my tool box..
Atlanta, GA. It looks like you're in NY ? I'm actually gonna be up there for new years .
Old 12-06-2010, 07:34 PM
hrpfg2's Avatar
part number: 12040PCX305
you dont want to wait till new year to get the gasket.
Old 12-07-2010, 05:51 PM
Thanks, is this the part number for the valve cover gasket and the spark plug seals or just the valve cover gasket only?
super_mut
05-13-2013 12:12 PM
keith2.2
11-08-2009 10:39 AM
S2WOOOW
10-03-2009 03:26 AM
littleandy
01-19-2006 04:33 AM
fish
08-06-2001 11:59 AM
Quick Reply: Oil on spark plugs and coil packs
