Oil on Spark Plugs
#21
But since you mentioned having high consumption issues, you still may want to find out what your comp and leak down numbers are. Determine if its rings through that process, obviously there isn't much you can do about that other then continue to drive the car until you get sick of adding a lot of oil or seeing smoke. But if it appears to be valve seals and guide related, then that's worth getting done. Burning a lot of oil isn't great long term if it can be resolved relatively inexpensively, compared to a full bottom end overhaul, which is what you would be looking at with rings.
Moddiction
10-31-2022 08:31 AM
Novotz
05-30-2017 02:29 PM
