Oil recommendation for ap2
Needsmorepower! (02-27-2017)
seriously?
1/2 quart in 5,500 miles in an s2000 forum. you know, instead of sympathizing with you, we would give you a trophy for outstanding s2000 engine of the year.
but to answer your question, go ahead and give 5w40 a try, no issues. if your budget allows you to stick with amsoil signature series, by all means stick with it.
otherwise, give motul x-cess 5w40 a try.
you need to appreciate your engine rather than worrying about the 1/2 quart in 5,500 miles.
I appreciate everyone's feedback. I do plan to keep using OEM filters as I learned from the start that they are one of the better options for the car. I also plan to send off an oil sample (as I do periodically) and hopefully *billman* will be able to double check my valve adjustments at deals Gap this year! I guess for now I'll stick with the 10/30 signature series as it's not extremely expensive when I use the preferred discount.
There are so many oil threads, but personally.. I always run OEM honda filters, no exception.
For oil I just use Castrol Edge Full Synthetic, 10W30, changed every 7500 miles with new gaskets each time, as I have a pack of 20.
Which gaskets do you change each time? Or are you talking the aluminum crush washer?
Thanks!
Thanks!
No problem! Thought I might be missing a gasket or two.
Needsmorepower! (03-04-2017)
