Oil Recommendation
Old 10-17-2000, 11:39 AM
Doug McCaw's Avatar
Bobrod, you
Old 10-17-2000, 12:05 PM
Pinky's Avatar
Doug your right and your butt meter isnt lying. It is faster! When you wait a long time to change the oil and then you do it fee's up lost power.
As for the oil. If you or a friend has a card at Costco I get my 6 quarts for only 20 bucks. Of course dealers and shops get it for like half that!!! Bastards!(V.T.)
Old 10-17-2000, 12:09 PM
laster's Avatar
Pinky, my dealer pays MORE for Mobil 1 than Costco charges. The parts manager showed my his costs and recommmended that I go buy at Costco. Unless the dealers sell a LOT of Mobil Oil they can't match Costco prices. BTW, the Costco here only has 10-30 in Mobil 1, what can you get?
Old 10-17-2000, 12:21 PM
cdelena's Avatar
Originally posted by BobRod:
Chris - I seem to recall that Honda recommends 10W30, or 5W40 in cold climates. Comments?
The low number specifies that the oil will not thin more than that viscosity in heat, the high number indicates the oil will not thicken higher than that in the cold. The W indicates it has flow enhancers for winter use. Honda recommendations vary depending upon where you look but the lowest viscosity I have seen is 5 and the highest I have seen is 40.
Based upon the studies I have read the most critical thing you can do is get oil to move when cold so I choose the lowest viscosity recommended. I also side with the position that today
Old 10-17-2000, 12:33 PM
FlyingPig's Avatar
I switched to Mobil 1 @ 12000 miles.
I also asked about engine flush....and got laughed at.
Old 10-17-2000, 12:38 PM
mingster's Avatar
mobile 1 or redline oil.
Old 10-17-2000, 02:28 PM
heffeme's Avatar
Just in case anyone wants some specific data on mobil 1, here is a link:
http://dallnd6.dal.mobil.com/GIS/MobilPDS....77?OpenDocument
The same data is available from castrol by mail.
Old 10-17-2000, 07:38 PM
kcopp's Avatar
FYI, Car and Driver's Patrick Bedard wrote an article for the November issue talking about the Castrol Syntec product. Interesting read. Should be posted at www.caranddriver.com soon or it's still on the newstand.
Old 10-17-2000, 10:32 PM
nvmys2k's Avatar
Synthetic Mobil 1 10W30 all the way w/ K&N Oil Filter or Mobil 1 Oil Filter!!!
Old 10-17-2000, 11:21 PM
NSXS's Avatar
originally posted by cdelena
BTW, fleet studies have shown that oil maintains its properties to lubricate for many miles (~12-15K) but it picks up contaminates and the additives deteriorate, so changing based on the calendar is at least or more important than the odometer.
Does this mean oil goes bad by sitting on the shelf? If the car sits in the garage a lot do you still need to change the oil in 6 months?
Quick Reply: Oil Recommendation
