Oil Recommendation
Old 10-16-2000, 06:32 PM
Big Al's Avatar
Give me some advice/opinions on what type oil to use in my S2000. I am considering Castrol synthetic.
Old 10-16-2000, 07:05 PM
Banned
gregstevens's Avatar
I went to Mobil 1 at the first change which I did at 7000 miles. I think most people have gone to synthetic, if not at the first change, then at the second...
Old 10-16-2000, 09:15 PM
pfb
pfb's Avatar
I recently read that Castrol was changing (has changed?) its synthetic oil from a fully synthetic base to a chemically modified organic (conventional) base.
There reason was it cost less to produce, but they did not plan on any cost reductions for the consumer...
I'd stick with Mobil 1 or Redline.
Old 10-16-2000, 09:17 PM
pfb
pfb's Avatar
I also went with a full synthetic (Mobil 1) at the first oil change, 3,000 miles. Modern engines don't need much breaking in. Many engines (Porsche, BMW, Ferrari) come with full synthetic from the factory. And specify LONG oil change intervals...
Old 10-16-2000, 09:24 PM
Prolene's Avatar
Thinking I was done with the breakin period and considering the dirty oil, I changed to synthetic too soon. I was burning much too much oil, until I switched back to reg oil for a time. Those extra long oil change intervals with synthetic as per Porsche may allow the engine to breakin if the synthetic loses its synthetic advantages along the way.
Old 10-16-2000, 09:41 PM
S2WOOOW's Avatar
pfb where did you hear that Castrol was going to non-sythetic base? Was it reliable? As far as I know, Syntec is still full synthetic. I can't imagine them changing it and still call it Syntec.
Old 10-17-2000, 03:35 AM
cdelena's Avatar
[QUOTE]Originally posted by S2WOOOW:
[B]pfb
Old 10-17-2000, 03:55 AM
VA S2K's Avatar
I switched to Mobil 1 synthetic at the second change, 7500 miles. The engine seems to be running better than ever. I would highly recommend the Mobil 1
Old 10-17-2000, 07:56 AM
S2WOOOW's Avatar
Thanks for the info. I'll keep a closer eye on what Castrol is doing. I agree that there is probably not much difference between synthetics, but are worth the money over conventional. I've been using Syntec (S2K and Grand Cherokee) and GTX (323 GTX) for the entire lives of my current cars, so I'll be reluctent to change. But if Castrol does something different with Syntec, then maybe...
Old 10-17-2000, 09:58 AM
BobRod's Avatar
Chris - I seem to recall that Honda recommends 10W30, or 5W40 in cold climates. Comments?
Quick Reply: Oil Recommendation
