Oil Question - 1/2 full!!!!
I have had my S2k for 3500 miles and have been checking the oil like suggested. It is now down to about half full. I guess the engine burns oil or there is a leak.
My question is, what kind of oil do I put in it to match what Honda puts in it new? I want to put in a 1/2 quart or full to refill it.
I have found in these forums that this engine oil burning is common with new s2ks.
If you only have to add 1/2 quart in 3500 miles consider yourself lucky. I burned 1 qt in the first 1000 miles under normal driving. Use a premium 10w30 non-synthetic oil to top it off. I used Castrol GTX.
John
John
snip ...
snip ...
Conventional board wisdom suggests not using sunthetic since it may not allow the engine to wear properly during break-in. However, I can't imagine how 1/2 quart of synthetic mixed with 5 quarts of factory oil could compromise the break-in process. The main concern for engine health is to keep the oil level full!
Yes, half way down the dipstick marks. Will do then.
Anyone else have any other suggestions for oil type and brand? Other than synthetic?
Utah
