OIL QUEST.(TEMP & PRESS)
What normal temperature of oil and its pressure??? At me gauges APEXi, cost near oil filter, at normal operation pressure at 90
according to the manual
engine oil pressure should be 36 psi (min) at idle and 85 psi (min) at 3000 rpm
Engine Oil Temperature should be 176 degrees F
I have both engine pressure and temp and I get roughly these numbers more/less depending on conditions, but they should be close overall
