Oil Pressure switch leak
I'm pretty sure my oil pressure switch is leaking. I took off the wire boot and it had oil inside. I don't see much oil above the switch so I think my TCT and VTEC selenoid are ok. I ordered gaskets for them just in case. From my reading I think I can just remove it, clean it, dab of Honda bond, and re insert. Question is, how do I remove the oil pressure switch? It has an odd shape.
I recently replaced my OPS' O-ring gasket. I used a shifting/adjustable wrench. Would be easier to remove your airbox to get a better angle around the bolt. Comes off easy once you do. Don't over-tighten when you reinstall. You may use some pipe thread on the threads if you like.
I just replaced my OPS o-ring last week. Seems like it's fixed the leak so far! Also seems like the engine is running smoother too, but that might just be the cool weather.
ateens4 (08-04-2020)
Cooler weather probably.
My OPS is dry now thanks to the new O ring but I noticed a little bit of oil residue collecting underneath the actual bolt even after I tightened it. Can you check yours as well and tell me if you feel oil residue there?
Bump?
