Oil Pressure Light Still Flickering
Old 07-29-2010, 02:37 AM
  #21
ifly1956's Avatar
but idk because my oil pan had a sh*t ton of metal shaving in it, no chunks or shards thank God.
This was not a good sign at all. I rebuilt mine when it hit 100,000 miles, and I didn't have any shavings. On the video - Maybe it was how it was recorded, but the engine does not sound good in my opinion. (it sounds "loose" to me)
Like others have said, get a true oil pressure reading as a start. If the oil pressure is good, readjust the valves. If you do have low oil pressure, the #4 bearing, then the #3 bearing are the last in the oil flow, so they are probably going to go first if there is an oil starvation issue.
A bottom end rebuild is not that difficult, and you don't need to pull the engine. I bought a new crank, ( $1,100) so it came with matching bearings. I never had an issue with my oil pressure, but I still installed a new oil pump.
Old 07-29-2010, 05:45 AM
  #22
idea-catalyst's Avatar
If the pan had metal shavings in it, everything in the engine is suspect. Don't expect that all of those shavings came only from the rod bearings. I'd suspect you've got some bad bearings elsewhere and I'd go with the long block replacement. Either that or a full teardown and rebuild.
Old 07-29-2010, 07:29 AM
  #23
JayDMEFHatch's Avatar
yah if thats the worst case scenario i'll tear it down and rebuild the bottom end...does anyone reading this have or know of anyone with a good long block willing to ship to 39556? ima post a thread up on WTB too so yah...shit sux
Old 07-29-2010, 07:30 AM
  #24
ima try postin up pics of the old rod bearings and the debris in the oil pan too.
Old 07-29-2010, 04:30 PM
  #25
posted up O/P test vid
climhazzard
07-05-2012 09:09 AM
Owen_1987
10-16-2010 02:19 AM
cyber_x
03-19-2009 06:46 AM
13darkknight
01-15-2008 04:49 AM
blacks2k
03-05-2006 03:31 PM
Quick Reply: Oil Pressure Light Still Flickering
