oil pressure guage leak
the guy who had the car before me installed an oil pressure guage and now i check it and its leaking where it connects to the engine....i just want to take the dam thing out but im not sure what plugs into that hole in the engine where the guage used to be connected. any help or pictures would be great. thanks in advance.
you can see the clear line and where it connects to the block...once i turn the car on it starts to build up under there and eventually start dripping...
well i put teflon tape on it and just made sure that it was nice and tight and it doesnt leak anymore...now theres another problem lol...i have a small leak that somehow is accumulating and getting under the fuel filter...any help?
Oh ok.
I would start by cleaning that side of the engine. Use some foam degreaser and wash it. The I would change that oil filter to an original Honda filter. Once you do that it will be easier to pinpoint the leak.
It could be from the oring between the oil cooler and the block, but I doubt it. The oil cooler is the donut that sits between the oil filter and the block.
J
J
