Oil Pressure Gauge
Oil Pressure Gauge
quik question - bought a set of gauges and an pod
the oil pressure gauge did not come with an adaptor - can i safly remove where the stock sending switch ties in and connect my oil pressure nipple to that point??
Gs2k made a valid poimt today and recommed that i buy an adaptor because the ecu would not see the oil pressue if i simply cut the wire off
Thanks guys
steve
Thanks guys
steve
i'd suggest getting a greddy oil filter adapter. if memory serves, the deal that's there now just decides whether your dummy oil light is on. it doesn't feed to the ecu.
The oil pressure switch in the block is 1/8BSP. (british straight pipe) Most oil pressure sending units for aftermarket gauges are 1/8NPT (national pipe thread) NPT threads are tapered, versus BSP threads which are not.
The oil pressure switch in the block is for the oil light in the instument cluster, it is not wired the car's computer.
The VTEC oil pressure switch is wired to the cars computer, it does not always recieve oil pressure. It would not be a suitable location for a gauge sender.
If you have an autometer gauge, the sender is NPT.
There are 2 ways to install the sender. Either a oil filter block adapter,(like the Greddy) or use a section of braided stainless hose and a T- fitting to supply oil to the sender remotely. If you mount the sender directly to the T-fitting, you have a very good chance of the T-fitting breaking. Due to the weight of the sender and the vibration from the running engine. Several people have done this and broke a fitting in the block, and had oil spraying under the hood. Not to healthy for the engine and quite the fire risk.
There are 2 ways to install the sender. Either a oil filter block adapter,9l(like the Greddy) or use a section of braided stainless hose and a T- fitting to supply oil to the sender remotely. If you mount the sender directly to the T-fitting, you have a very good chance of the T-fitting breaking. Due to the weight of the sender and the vibration from the running engine. Several people have done this and broke a fitting in the block, and had oil spraying under the hood. Not to healthy for the engine and quite the fire risk.
i think i'll give it a shot if i can find the proper T fitting since i don't think there will be added stress
awesome info - thanks again!!
08s2000CRbackinblack
07-09-2011 09:41 AM
vaamntxoovzeb
08-24-2010 09:18 AM
