Oil pressure drop when VTEC kicks in
Oil pressure does drop at VTEC, it's normal
https://www.s2ki.com/s2000/topic/978...temp-readings/
But probably not normal to be so low at high rpm
I am running long oil cooler mishimoto lines and the oil pressure sensor has a 5 inche remote hose too..but never saw this issue on the dyno before the very first one long pull on which I think I lifted the head a bit as I saw the thermostat housing leaking water under boost (even using full blown larger h11 head studs) I retorque head to 100 pounds but problem is still present
this is annoying, I will have to bypass the oil cooler and see if the mishimoto oil cooler setup on a 600 whos turbo S might be the cause for this
