Oil pan removal and install?
It's a pretty simple task. You have to remove the brace that sits underneath the pan(I think 4 bolts). After that you have to remove the bolts for the AC compressor then you can unbolt and remove the pan.
Try searchin the forced induction threads they are always dropping the oil pans to put in oil return lines. When i took mine of it was pretty straight forward. But its a pain especially if you dont have a lift. Get comfortable laying down there because there are like 13-15 bolts in the oil pan.
