Oil over fill, how much is too much?
Originally posted by Kyushin
The bubbles were not there in the morning after a cold check, only see the bubbles after driving.
Banned
So you dont think i have a problem? As of right now, i am only takin the car out about 15-20 miles just to get to work and i am taking it to honda sat for an oil change.
I recommend an oil analysis to help figure out what the "little bubbles" are. They could be air bubbles due to an overfill condition, or water droplets as xviper suggested. Doing the analysis will take the guesswork out of this armchair analysis. I use Blackstone Labs, but there are several others to use as well.
Also, it is generally a good idea to keep the oil level at the full mark. It sounds like you are still about 1/2 quart low. Please clarify - is the oil level "3 diamonds" above the lower line on the dipstick? Or, is the level above the upper line?
Originally posted by jyeung528
after I drive and turn off the car, I check the oil after 3 minutes and fill it up to FULL.
I guess I overfilled!!!! damnit.
It might be interesting to note that our engine has a "slosh" shield just under the crankshaft and above the oil. Even if you overfill enough for the crankshaft to slam into the oil, only that small layer will get foamed. The critical oil that the pump picks up will be fine. This is NOT saying that if you overfill by a lot, that this extra quantity won't cause a problem.
