Oil on my sparkplug thread...HELP!!!
Yesterday, I changed out my OEM spark plugs to Denso Iridiums. All the other spark plugs look fine, but the forth plug(closest to the firewall) had oil on it's threads. Does anyone here know what that could be? I couldn't find anything about oil leaks in spark plugs with the "Search". I have a little over 14,000 miles on and it's a 2001 S2K. I change oil & filter at every recommended intervals. Any help would be appreciated.
I use a funnel for pouring oil in. I will have to remove the new spark plug later to see if there is still oil on there. I hope it nothing major...or else it's time to take her into the dealer.
I am pretty sure that is normal. You are always supposed to put oil on the threads of the plugs before putting them in. Mine had a little oil on them in the threads and in my Civic samething.
Justin
Justin
I think you can put whatever can withstand alot of heat and won't dry up. You don't soak it with oil, just a tiny bit on the threads. Was your car running any different? As far as I know, and I've seen, it is normal.
Originally posted by S2K
I thought that you were suppose to put anti-seize on the thread, not oil???
Madkows
08-20-2020 12:06 PM
S2WOOOW
10-03-2009 03:26 AM
