Oil light stays on 1-2 sec at startup, when hot!
#51
I think his were either an odd bad batch or a supplier issue. He is in Germany. Not sure where Honda over there sources oil filters. Like if vendor uses a different factory to supply different markets.
windhund116 (04-10-2024)
#52
All baby blue filters are made by Mahle in Thailand, they should come with a free can of Red Bull.
#53
And virtually no one else has had this issue with the Honda filter. So there was something else going on there. It makes no sense to think the filter design is faulty or we would all have this issue.
The only other reports I have ever heard of the oil light staying on longer than normal (Outside of this thread and what Matchbox said) is after people swap the Ap1 banjo bolts to the AP2 ones. Never heard any issues from it, just that they notice the oil light stays on an extra second or so.
The following 2 users liked this post by engifineer:
Mr.Matchbox (04-10-2024),
#54
Virtually no one else has had this issue with the Honda filter, so there was something else going on there. It makes no sense to think the filter design is faulty, or we would all have this issue.
The only other reports I have ever heard of the oil light staying on longer than usual (Outside of this thread and what Matchbox said) is after people swap the Ap1 banjo bolts to the AP2 ones. Never heard any issues from it, just that they notice the oil light stays on an extra second or so.
It's too late to change oil filters; the engine needs a rebuild.
#55
Bad oil filter drainback valve. Supposed to hold oil in passages, so immediate oil pressure next startup. If valve is bad, passages drain, next startup, has to fill them back up before pressure.
Normally a new filter cures it. Guessing you got a bad batch of filters.
#56
I’m guessing my knocking on startup is definitely the bearings…. I literally just had the shop replace the bearings like 200 miles ago and it’s been knocking on startup ever since
#57
I propose to keep all pertinent info in one thread otherwise it is impossible to follow and provide info.
#58
Yesterday i started my S2000 again after 5 months of Winter storage. Oil light went off in 1 Second. I would call this "Perfect". Non OEM, smaller size oil filter.
#59
Yes, my engine has the upgraded Banjo Bolts. Regarding the "Problem" i also think that most likely i am one of the very, very few persons who actually care about the time the oil light takes to go off. I bet 90% of the owners just dont care.
Do you know why putting AP2 oil banjo bolts into the AP1 block causes this momentary low oil pressure on startups?
Are the oil pressure sending units different between the AP1 and AP2?
Thanks!
#60
When I heard people talking about this, I checked mine, 1 second and the light is off for sure. I would say less as it turns off as soon as the engine speed comes upon starting like my others cars do.. OEM filters, stock banjo bolts. Oh and that was the first time the car has been started since early November so I would say worst case for sure. It has been sitting on a Battery Tender since then.
climhazzard
07-05-2012 09:09 AM
BlitzSRM
05-03-2004 10:52 AM
