oil light flickering at idle *sometimes*
#41
Im having the same issue with the oil light flickering at idle sometimes as well, along with the car dieing out when the clutch is pushed in coming to a stop, and a power loss and no real transition into vtec. I did a compression check the other day, turned out fine. Would this rule out the main or rod bearings?
#44
no that would tell you if air is leaking from your rings, or intake and or exhaust valves.
the mechanic probably dropped the pil pan and inspected the rod bearings and then the mains. or at least around the mains
