oil light
If you kept the rpms and load low, your engine may be fine. If you were to vtec with 1.75 quarts remaining, it would pull the remaining oil out of the pan, drainback from the top end would not keep up, and you would suck air and lose all pressure (instant spun bearing).
There is a layer/pool of oil that sits between the windage tray and the block, that lines up with the full mark on the dipstick. This layer coats one side of the stick, resulting in a false reading.
Check it in the morming (the false layer drains off) and check both sides.
I have checked the oil on every car in existence, and the S2000 is the only car I know that has this problem.
May or may not have: tapping rod bearing noise, metal in oil, loss of oil pressure.
Only way to know for sure is to remove oil pan. Remove bearing caps and inspect bearing & crank surfaces.
It would cause the sample to read really high on fuel content , and dirt (silicon), so just ignore that data in the used oil sample report that you would receive. You are most interested in bearing wear numbers for lead and copper, and perhaps iron (cylinders, cams, rockers), and aluminum (pistons and journals etc.).
In my case even dropping the oil pan didn't reveal anything, so I buttoned it back up with a Mugen oil pan for extra insurance, and then the engine self-destructed a few miles after that.
One check you can do is to remove the vtec solenoid and check for metal particles on the screen, if you see metal particles then you definitely have issues below. But on the flip side, a clean screen does not mean things will be problem free in the future, it is an easy check though.
So, either you damaged the rod bearings due to oil starvation, or you didn't. These oil sample tests everyone is discussing is one way to know.
If damage did occur, if you can find someone that knows how to do this, and most mechanics don't, you can polish the crank and replace the bearings, with the engine in the car. Not too expensive.
Vs waiting and seeing, which would be waiting to see if you get rod knock (a loud, knocking sound from deep inside the motor, most pronounced at idle). If you hear this, and stop motor immediately, it still may be possible to fix, but this means more damage has been done.
What's the thought about running heavier weight oil (like 10W-40, 20W-50, or straight 30W) in cars that have this issue? Help dampen the noise and perhaps, reduce oil consumption.
Thanks!
Thanks!
