oil leaking
Old 05-13-2007, 10:08 PM
v2deLsoL's Avatar
Default oil leaking
did a search on the word "porous" because i'm experiencing this "leakage" and wondering if i should i care? the leaking is almost impossible to pinpoint and all i see it grim collecting on moisture. how to fix? should i fix? it bugs me ALOT.
here are some pictures i found if you folks don't know what i'm referring to. (NOTE: these are not my pictures, just examples of what i am trying to illustrate)
Old 05-13-2007, 10:44 PM
AusS2000's Avatar
Hmmm, it doesn't look bad enough to bother with.
I had my block replaced at 13,000Km due to porosity but Honda picked it up at the 10K service and did it under warranty.
On the weekend I was speaking with Chris Barry and he mentioned a process where they immerge the block in a liquid and it works it's way into the pores and hardens. But it will still require a huge pull down and lots of work.
Old 05-14-2007, 03:14 AM
trapper's Avatar
I noticed that "seep" at exactly the same place [at the gasket seam between the two bolts] couple of months after I got my MY04. I cleaned it up and it never came back. I believe there's a thread someplace that indicated that this is a fairly common event with a new S.
Old 05-14-2007, 06:06 AM
v2deLsoL's Avatar
although it's common, it's still a defect... which sucks. i have an 07 w/ 5k on it and i was totally confused as to how this could happen.
Old 05-14-2007, 06:42 AM
trapper's Avatar
In most cases I don't think it would warrant being called a "defect". My understanding is that the seepage is from the oil that's on the gasket and/or from the plug above it when it's installed bleeding out as the engine heat cycles when it's new.
Clean the seepage up ...... if it comes back you may indeed have a problem..... if not, forget about it. As I said in my earlier post I had the same seepage [I noticed it about 3 months after I got the car]. I cleaned it up and 2-1/2 years later there is NO sign of further "leaking".
Old 05-14-2007, 07:49 AM
cdelena's Avatar
[QUOTE=trapper,May 14 2007, 08:42 AM] In most cases I don't think it would warrant being called a "defect". My understanding is that the seepage is from the oil that's on the gasket and/or from the plug above it when it's installed bleeding out as the engine heat cycles when it's new.
Old 05-14-2007, 09:43 AM
jyeung528's Avatar
interesting...
mine's is fudged up. i have oil stains all over...
Old 05-14-2007, 11:20 AM
trapper's Avatar
Originally Posted by cdelena,May 14 2007, 10:49 AM
It is absolutely a defect... ......
Whatever .... just relating my experience and the experience of many others....
Old 05-14-2007, 01:31 PM
v2deLsoL's Avatar
well, i'm not here to argue about it. I just want to know how to fix it.
so is this a head gasket issue? or is this a porous block issue? 2 totally different areas. when i change my oil again, i'm going to degrease my block and REALLY clean my problem area. Hopefully, it goes away...
Old 05-14-2007, 01:57 PM
cdelena's Avatar
It is a porous casting on the portion of the head covering the timing chain gallery. 99% of the time you can just clean it and ignore it. On the real bad ones Honda has replaced the head under warranty.
Quick Reply: oil leaking
