Oil Leak Under Timing Chain Tensioner?
Old 01-12-2010, 10:47 PM
toniotran's Avatar
Thumbs down Oil Leak Under Timing Chain Tensioner?
Hey all,
I've noticed a rather small oil leak right underneath the auto timing chain tensioner. Over time the oil leak has been large enough to produce drops under the car. I thought that by cleaning the contact surfaces and retightening the bolts to spec the oil leak would go away, but apparently after feeling underneath the timing chain tensioner the oil leak is still there. Any suggestions or helpful insights on how I may stop the oil leak would greatly be appreciated.
TIA,
Tony
Old 01-13-2010, 11:04 AM
toniotran's Avatar
Old 01-13-2010, 11:13 AM
s2k dre's Avatar
Pull the tensioner out and check that o ring. it might be ripped.
Old 01-13-2010, 11:30 AM
toniotran's Avatar
O-rings were still intacted but I did noticed that they were on loose enough to rotate freely, could that be the cause for the oil to leak or are there anything else I should be looking for?
Old 01-13-2010, 11:38 AM
s2k dre's Avatar
Those are the only 2 seals on there! Unless ur vtec solenoid is leaking.
Old 02-14-2010, 06:46 PM
mavericckk..'s Avatar
any updates? im having the same problem.
Old 04-21-2010, 05:59 AM
booski's Avatar
x2
Old 04-23-2010, 09:22 PM
toniotran's Avatar
The oil leak could also be coming from the vtec solenoid and I was thinking whether I should undo both and seal them with a gasket maker or would that cause the contact surfaces to be uneven causing a potential oil leak?
Old 04-23-2010, 09:24 PM
toniotran's Avatar
or should I replace the rubber gaskets...anyone know the part numbers?
Old 11-21-2011, 11:28 AM
Road racer's Avatar
Any solutions to this problem.. I have the same issue. I replaced the VTEC solenoid gasket ( multiple-window o-ring with screen) and the TCT o-rings with factory Honda parts ( from the dealer). Still leaked.
Removed TCT & used a small amount of Permatex Silicone & torqued it back down to spec. Still leaks.
Replaced PCV valve (to eliminate any block pressure issues) and washed the engine (it's spotless now). Still leaks. With a clean engine I verified the oil is leaking from the TCT only.
Oil will collect at the bottom seam of the TCT & the block. The oil will drip off the right TCT bolt and run down to the oil drain bolt. Everything above the TCT is dry & clean.
Thoughts or suggestions? I am banging my head on the wall with this one.
Chris
Quick Reply: Oil Leak Under Timing Chain Tensioner?
