Oil Leak from Allen Bolt Cylinder Head
How do you replace the o-ring without completely removing the allen screw/bolt? Did you have to cut it then fit it around it??
Originally Posted by Billman250' timestamp='1274752911' post='18803938
I have done this job. Took 3 minutes.
It is very important you do not completely remove the bolt! You can loosen it just enough to expose the oring, then simply change it.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Received 1,652 Likes
Use a small pick to grab and remove the original o-ring as soon as it becomes visible when loosening the bolt. Then slide the new o-ring over the bolt with some oil lube as Billman250 explained. Torque the bolt to spec you don't want that coming loose as it will ruin your day.
Since its an Allen head the head is round, not hex, and the head is not that much larger than the o-ring, so its an easy stretch.
Suggestion, clean off the area as best you can before loosening the bolt. Then after loosening wipe bolt head clean before lubing o-ring and fitting it. You don't want to pick up any dirt or grit when you are stretching o-ring into place.
