Oil Leak from Allen Bolt Cylinder Head
![Thumbs down](https://www.s2ki.com/forums/images/icons/icon13.gif)
Here is a link of the exact problem that I am having: https://www.s2ki.com/forums/index.php?showt...&#entry14761113, and after doing a bit of searching I've found that there's an o-ring behind the bolt that most likely needs to be replaced but don't understand how the o-ring can be replaced without completely pulling out the allen bolt if that is even possible or is it???
. If anyone knows how please help
![ponder2.gif](https://www.s2ki.com/forums/images/smilies/ponder2.gif)
![heart.gif](https://www.s2ki.com/forums/images/smilies/heart.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I have done this job. Took 3 minutes.
It is very important you do not completely remove the bolt! You can loosen it just enough to expose the oring, then simply change it.
Originally Posted by toniotran,May 24 2010, 08:23 PM
and by simply changing out the rubber o-ring, this will stop the oil leak?
