Oil leak?
Oil leak?
I changed my differential fluid a few days ago and made sure my engine oil was full took about 1/2 quart. I noticed a oil spot in my drive way last night and decided to go under the car and see what if i could figure out where it was coming from. i went and looked at the rear differential and it is fine so i went under the front left and found this.
I checked my oil today and it is half way down the dipstick but it was kinda cold and i checked it hot last time. Also i cannot find where the oil is coming from there is none coming from the engine. And all the places that have oil on them have barriers that the oil if coming from the engine would not be able to pass.
Ok oil cap is there and on correctly so is the oil filter. and yes it is only on the drivers side.
Also when i changed my differential fluid i ran over like 1/2 quart bottle and got some on the tire but not ass much ans i am seeing on the underside of the car.
Odd that you didn't mention you ran over 1/2 a qt of fluid.
