oil gone
The recommended way is to read the dipstick with the oil hot, 5 minutes after engine shut down. Remove dipstick ,wipe it off, rreinsert it, pull it out again and read both sides. Use the lowest reading as the accurate reading, one side will be higher than the other. If you just pull out the dipstick without cleaning and reinserting it the error reading will be even worse. You can read the oil cold if you like, but be consistent with it as the readings will be different between cold and hot, don't read it cold one week and then read it hot the next week as there will be differences. Check your oil often , every time you fill up for gas is a good rule of thumb. Going one quart low is enough to do some damage on an ap1.
The worst time to check the oil is cool or warm, right after the engine's been running, like what you'd do immediately after an oil change. Oil that hasn't reached operating temp will not fall back down into the crankcase very efficiently and you'll get a low reading. Topping up then is more likely to produce an overfill.
Originally Posted by 2003AP1' timestamp='1340689098' post='21811641
[quote name='JFUSION' timestamp='1340667083' post='21810803']
[/quote]
Where in the manual does it state that it is more accurate when it is hot? I can not find it.
What you say seems contradicting. However its best to check cold. Once all the oil is at the bottom of the pan gives you the most accurate reading.
Seperate from that you should check it every gas fill up even if it is hot. However this is not as accurate as a cold check it is reccomended you check it.
Hope that clears it up.
well the main thing is to check your oil often and use a consistent method - cold or hot for accuracy. There will be a difference between hot readings and dead cold readings on the dipstick, you cant really go wrong either way as long as you are consistent.
