Oil Filter Question
Old 11-25-2010, 06:57 PM
PWRMKR's Avatar
no it won't explode.
fram is a leader because of marketing, price, availability, and our stupidity.
Old 11-25-2010, 09:05 PM
flyingtoaster's Avatar
Originally Posted by turbodriven,Nov 25 2010, 06:09 PM
So what you are saying is that my car will explode in a fiery blaze if I use FRAM.
I understand that it's not "the best" filter out there. In terms of internal materials used. But I've put well over 150,000 miles on various cars/trucks while using them and never seen a problem yet. So have hundreds of thousands of other drivers. The fact that they are leaders in the filter manufacturing game has to say something no?
Its not entirely correct that I'm saying Frahm is not the best filter. What I am saying is that they are the worst. But you are right in that your car will not erupt in a fiery blaze. If that is your concern, continue using the orange can.
Old 11-25-2010, 09:17 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
as bad as cardboard end caps sound and look, I've yet to see a documented case where the Fram parts had failed or caused issues. Metal end caps certainly look much nicer and provide greater peace of mind. I know in the past Honda had Fram construct some of their oil filters, they rolled out of a Fram manufacturing plant that is 20 minutes down the road from my home. I'm pretty sure they had the cardboard end caps in them. I prefer to run the Honda filter on my S2K simply for the fact that I know that it will flow the proper rate of oil that engine requires.
Old 11-26-2010, 05:11 PM
OneSilverS2k's Avatar
I use the Honda filters, or the Boush. the Boush costd like 15.00 a filter though but I get 1 free with the 5 qts of Castrol edge full syn
Old 11-26-2010, 06:16 PM
idea-catalyst's Avatar
Originally Posted by kulo,Nov 25 2010, 01:43 PM
15400-PCX-004
You can't buy better insurance for less.
Old 11-26-2010, 06:33 PM
TyFoxx0608's Avatar
I use only mobil one or hamp. OEM filters are made from FRAM.
Old 11-26-2010, 06:46 PM
https://www.s2ki.com/forums/index.php?showt...=0&#entry447972
Fram + ; Fram -
there are both opinions, but there are several threads that have pictures of disassembled filters and the Fram filters don't show up very well.
Old 11-26-2010, 09:01 PM
Fram + ; Fram -
Its the easiest thing to find on google. At best, the cardboard flexes a little and distorts the media pleats. At worst, the cardboard tears and the pleats collapse. It still baffles me that people buy these when they know what th filters are made of. Metal doesn't distort and collapse the media. Plus, frahm uses poorly fitting, stiff rubber anti drainback valves. Rubber shrinks and hardens ith prolonged oil contact.
Old 11-27-2010, 12:05 AM
H22toF20's Avatar
I only run K&N or Royal Purple.
Old 11-27-2010, 03:01 AM
HondamakesS2000s's Avatar
Most studies and forums ive seen seem to be #1 HONDA OEM and there is the cheaper mobil 1 (but i think it IS the oem filter). Then Purolator PUREONE (best value) or K&N (also expensive) with similar results. FRAM is the poorest quality with the exception of FRAM2X (their "stronger filter").
I go with Mobil 1 or Purolator PUREONE. If you really want OEM, then I would check to see if Mobile 1 is the same filter. I have heard Honda just uses the Mobile 1 filter as their OEM filter, of course without "Mobile 1" on it.
Quick Reply: Oil Filter Question
