Oil Diff
#24
You say: "only local brands"
What brand?
Or have thay bottled oil that they drilled for themselves in their backyard?
Put it in an old Cola bottle, label it with a home made label saying nothing else than SAE 90 GL-5?
C'mon...
Serious: if quality is a question go for the SAE 140.
Drive conservatively for 10 miles or so during cold (@ freezing temps - IF the temps drop that low where you live) mornings.
What brand?
C'mon...
#26
hey guys i bought the SAE90 GL-5 oil, and the color is green!!
i think the oil in the DIY fluid change is red,
ok to use the green one?
#27
Produced from premium crudes
On the website of Plogco I found some specs of the SAE 90 / 140 gear oil they make for several brands (all links from different brands showed the same specs)
Code:
CHARACTERISTICS TYPICAL VALUE .....................90 - 140 Sp. Gravity @ 15o C 0.901 - 0.913 Viscosity @ 40o C, cSt 220 - 460 Viscosity @ 100o C. cSt 19 - 31 Viscosity Index .......97 - 95 Flash Point, COC, oC...268 - 292 Pour Point, oC ....... -6 -6
Its not LE-607 either. (that is the red oil)
You've got enough for at least 4 changes.
I would change it out every 10k km or once a year.
#29
Looks good enough to me. I agree with the 10K OCI too. They use this for motor oil too? Interesting. I would think a different addititive package would be desired/reqiured for a high compression IC motor.
